GM Recall Campaigns For Information & Discussion of General Motors Recalls
Airbag harness recall
Old Feb 21, 2015 | 12:27 AM
So far, seems only '09 HHRs' are in this recall.. But time will tell..
Old Feb 21, 2015 | 07:58 AM
fastsuv's Avatar
The definition of "fretting corrosion" is:
Fretting corrosion is a form of accelerated atmospheric
oxidation which occurs at the interface of contacting
materials undergoing slight, cyclic relative motion.
In electric contacts involving non-noble metals,
fretting action can cause rapid increases in contact resistance,
proceeding to virtual open circuits in a matter
of minutes in the worst cases.
In other words, the connector contacts moved very slightly from vibration, causing corrosion, which causes high-resistance.
When I was designing military electronics we always used gold-plated contacts (the "noble" metal) to avoid this problem (among other issues that gold contacts fixed).
Interesting that only one year seems to have this problem (so far). Maybe a different design/vendor for that year.
Steve
Old Feb 21, 2015 | 08:17 AM
Yeah! I slid by my Chebby dealer yesterday they checked my vin and said no reason to concern myself with this recall for my '07.
It was -12 F so very icy and cooolld , but the service writer got me a hot chocolate and let me hang out for 45 minutes enough for the car to shed most of the ice built up in the wheel wells !
Old Feb 21, 2015 | 02:22 PM
jimfet's Avatar
Got mine today. I think they are trying to sell new cars.
Old Feb 21, 2015 | 02:37 PM
Michaeljschaaf's Avatar
I also have an 2009. I received a letter from G.M. To make an appointment with dealer to have a replacement of in-line jumper wiring harness connector with fretting corrosion at the terminal contacts. Dealer replaced unsealed connector with a sealed connector. Took about 1 hour. So far so good, no more air bag lite.
Old Feb 21, 2015 | 02:53 PM
BlindLizard's Avatar
Bummer. Have '09 too. This makes the 5th one? I will have to call dealer to put my name on the service list.
Old Feb 21, 2015 | 04:28 PM
Anybody notice the link in post #4 ? Just click it then input your VIN.
Old Feb 21, 2015 | 07:10 PM
I did
Old Feb 24, 2015 | 05:14 PM
pstar's Avatar
I'm assuming this pertains to the right kickboard panel wire issue? I've pulled that wire and lubed it and whenever it rains the warning light comes on for a while until the humidity in the car drops and then goes off. It rains seldom where I live. So, it's definitely moisture/humidity related. I still have to get the ignition recall done. Do they only cut you one key? Wjat about key fobs?
Old Feb 24, 2015 | 05:21 PM
2 keys are included in the kit. No new fobs because they aren't part of the recall or the problem.
(somewhere on this site I posted a picture of the recall kit and it's contents. I'll see if I can find it. )
