09 Front end noise over bumps
Old Mar 7, 2019 | 12:25 PM
YoCristi's Avatar
Unhappy 09 Front end noise over bumps
I just finished paying almost $800 to repair my front Struts with an alignment, but I can still hear "that" noise coming from the front end each time I go over a speed bump. WHA! Not sure what it could be?
Old Mar 7, 2019 | 12:30 PM
Welcome to the site,
Rear lca bushings, swaybar end links, swaybar bushings, upper engine mount.
loose bolts , an air gun is not what should be used to replace a torque wrench!
Ive had HHR’s with new LCA’s and the rear bolt was only tightened to 53 ft lbs, guess that mechanic needs a new air wrench!
Loose bolts at the transmission mounts can also be a source of noises, along with the front bumper cover and ball joint pinch bolts!
Old Mar 7, 2019 | 12:56 PM
YoCristi's Avatar
Good start
I had previously had the front sway bar links replaced and so the repairman said that those didn't need to be replaced this time. I will have him recheck, considering the other suggestions.
Thanks for the advise, I will post on what we find.
Old Mar 7, 2019 | 02:15 PM
Well then look at the sway bar bushings.
It seems , he might not be as familiar with the Delta chassis as we are.
Here’s a guide
https://www.chevyhhr.net/forums/prob...g-pop-s-50648/
Old Mar 7, 2019 | 02:54 PM
DrLoch's Avatar
Did they by chance replace the lower control arms with the wrong ones?
Old Mar 7, 2019 | 03:03 PM
Don’t get me started on steel LCA’s !!!
Old Mar 7, 2019 | 05:36 PM
OP didn't say control arms were replaced.
Old Mar 8, 2019 | 07:24 AM
DrLoch's Avatar
Understood, but, he also hasn't elaborated on what exactly was changed. That is why I threw that out.
Old Mar 8, 2019 | 07:36 AM
"She" also hasn't described the noise.
Old Mar 8, 2019 | 07:52 AM
Sure she did. You know, "that" noise. (whatever that means)
