2.0 question
Old Jul 11, 2020 | 11:07 PM
Kc0kfg's Avatar
2.0 question
Odds are I will go with a zzp in the end but I wonder.
Another place has offered to sell me a 2.0 with forged pistons and rods for less,
But and this is my concern they are using a used block
I asked if they are overboard and they said no (I know not to thin the sleeves any more)
Are these blocks wearing that well that you can hone them and fit new pistons?
If so, I will just get a block and build my own,
thanks friends
Old Jul 12, 2020 | 07:43 AM
The Ecotec cylinder block is sleeved , that shouldn’t be bored, but new sleeves installed
88984129 Ecotec Cylinder Sleeve 2.0 LSJ & LNF, 2.2 L61, LAP,LE8
so , if available you could go to 3.0 litres maybe more , there are companies out there that build these Ecotec engines for desert racing .
Old Jul 12, 2020 | 09:34 AM
The LNF already has forged rods, but cast aluminum pistons.
Old Jul 12, 2020 | 09:44 AM
What did your LDK engine come with RJ?
Old Jul 12, 2020 | 10:07 AM
The LHU/LDK is the same. Here is some good info https://forum.hptuners.com/showthrea...DK-LHU-Compare
Old Jul 12, 2020 | 10:26 AM
And the forged crankshaft.
Old Jul 12, 2020 | 09:29 PM
Kc0kfg's Avatar
thanks friends[/QUOTE]
Old Jul 13, 2020 | 04:44 AM
thanks friends
[/QUOTE]
Depends. But you may want to consider the year of the LNF block you would be using. There were some porosity issues in some of the earlier 2.0 blocks. Do a Google search on "2.0 LNF porosity". (think that's the correct spelling) There's a few interesting articles.
If it was my car, I would be looking at the LHU or LDK.
Old Jul 13, 2020 | 04:53 AM
Cat Man HHR's Avatar
thanks friends
[/QUOTE]
If there is no scoring on the wall and it doesn't have a ridge or excessive tapper, it can be honed.
Old Jul 13, 2020 | 07:25 AM
But not by much , those steel sleeves in that aluminium block aren’t very thick so if there is a ridge or the bore is worn , you can’t bore the sleeves you have to replace them.
