2009 hhr
how can a 15 inch wheel be made to fit a 2009 hhr ss
2004 or 05 Malibu Max rims if you have the Standard SS brakes , if you have Brembos then no 15 inch rims will fit
Originally Posted by Steve Gilbert
(Post 831490)
Easy-peasy as you don't have to disconnect the brake lines. 14-1163 & 14-1164 brackets on rockauto for $25 each 22705303 & 22705304 from GM for $65 each. Centric rotors for $30 each $120 total to run 15" wheels on the front with new rotors & reman brackets. A lot cheaper if you go to the bone-yard or craigslist.....:twothumbs: And correct, you can't use 'Brembos' as they are way too big. |
