2009 hhr
Old Oct 15, 2017 | 06:28 AM
Steve Gilbert's Avatar
2009 hhr
how can a 15 inch wheel be made to fit a 2009 hhr ss
Old Oct 15, 2017 | 08:32 AM
2004 or 05 Malibu Max rims if you have the Standard SS brakes , if you have Brembos then no 15 inch rims will fit
Old Nov 23, 2017 | 01:29 PM
2005HHRauto's Avatar
You just need to use the HHR LS/LT caliper brackets & rotors, if you have the standard HHR SS brakes.
Easy-peasy as you don't have to disconnect the brake lines.
14-1163 & 14-1164 brackets on rockauto for $25 each
22705303 & 22705304 from GM for $65 each.
Centric rotors for $30 each
Amazon Amazon
$120 total to run 15" wheels on the front with new rotors & reman brackets.
A lot cheaper if you go to the bone-yard or craigslist.....
And correct, you can't use 'Brembos' as they are way too big.
etsuHoopsFan
Tires & Wheels
18
Aug 19, 2017 01:58 PM
Schreiner.Photo
Sep 2, 2010 06:44 PM
GDZHHR
Dec 7, 2008 05:23 PM
MikeX
Jun 14, 2006 04:46 PM
