4 days and still not fixed
i just got my car back from the dealer they were suposed to fix the loud clunking noise witch is the throw out bearing.i looked at the paper it said new plate kit and sensor they did not even replace the throwout bearing! the paper said replaced and no noise is heard anymore also that there was no visual problems.Now my clutch pedal is real loose to half way pushed in then it gets harder.way more messed up now then it was.I knew i should have just drove it till it blew up.
Time for a new dealership if that's possible. And don't mention the prior service or they may decline to work on it and tell you to go back to the original dealer.
Originally Posted by ChevyMgr
(Post 306935)
(Post 306935)
(Post 306935)
My dealer can tell me when and where any dealer did any work and what for just by pulling my VIN. |
anyone got any ideas? call complain or what or just deal with it i dont know.
Originally Posted by jerSSey HHR
(Post 306939)
They can't do that, can they?
Originally Posted by Lone Ranger
(Post 306940)
Don't dealer service dept.'s usually run a warranty claim history on the car before servicing it for a medium or large problem?
Mgr, you got servide advisors like taht too? Man I thought that was only in New Braunfels. I think we have an advisor that can't read. Let alone hit the print button on VIS or history.But he can write them all up as "water check engine lights" at 11:45 right before lunch. He doesn't do that to much anymore.
Originally Posted by twistedamd
(Post 306946)
When I had my 97 C5, I had to go through 3 different dealers before they figured out what was wrong. I needed a BCM, but it took the 3rd dealer to discover the problem.......Don't just deal with it, get it fixed..... Just saw ChevyMgr message above about not revealing you already had work done, I disagree with Brad on that one, because as stated when they run your VIN, they will have the service history in front of them. And I never had a problem going to another dealer, except that if you aren't one of their customers, they will fit you in after they take care of their customers first, so you mat have to wait a little longer for an appointment..... |
If I am correct all chevy dealers has to abide by the rules of GM. This goes for the service dept. Contact the manager of the service department and explain how u feel. If he/she doesnt correct the problem just contact GM 1800 number and file a complaint. The district representive will contact the service department to find out whats going on and correct the problem without you having to deal with it. When I contacted the customer service department for my problem...they called the dealer within hours and the manager himself called me to apologize for any inconvineces. Just my .02
