6 speed
Old Feb 11, 2012 | 07:47 AM
hyperv6's Avatar
Originally Posted by JoeSchmoe
The juice just would not be worth the squeeze....
That sums this up as well as anyone could state.
Old Feb 11, 2012 | 08:51 AM
db/sb's Avatar
In way less words than I used................
Old Feb 11, 2012 | 08:54 AM
db/sb's Avatar
Originally Posted by jsis7895
ps steve if I had 5 or 6 cars to spread the milage on.... maybe it would take me longer to hit 100k
The mileage isn't 'spread' per se. My wife drives the HHR exclusively. The Ranger is my dalily driver. The other cars are basically toys.
Old Feb 11, 2012 | 07:49 PM
BZERKED's Avatar
I was thinking the same thing but not G6. I have been waiting to check out a 2012 Buick Regal GS Turbo... I am thinking that might be the ticket since the wheel base is very close. When I am running on the highway I so want to grab 6th
Old Feb 12, 2012 | 07:47 AM
Was mulling this 5 speed/ 6 speed swap over in my head. Does anyone have some gear ratio comparisons between the stock 5 speed and a possible 6 speed replacement? Seems to me the final drive gear ratio on the 6 speed is
"not" going to achieve what the OP wants.(rpm drop) A straight trans swap won't change the final drive ratio much,if at all. Wont matter what trans you put in there unless it has the right gearing. You could put an 8 speed in but if it's not geared right whats the point.
If someone can find some gearing comparisons I think it would shed some light on this.
All else fails.Slap on some 26"s and watch the gearing and rpms drop.
Old Feb 12, 2012 | 07:55 PM
  #26
Chevy13's Avatar
What about the Cruze 6-speed?
Old Feb 12, 2012 | 09:31 PM
  #27
jsis7895's Avatar
maybe i should try a different approach, I think GM dropped the ball, the solstice gxp, cobalt ss,..... all performance "type" cars that are manual should have 6 speed, 4 speeds were fine for the 60's and 70's , mid 80'-90's 5 speeds and natural proggression... 6 speeds. My last car a 03 svt focus had 6 speeds not that the 6th gear helped economy but it could have. there are plenty of manufacturers producing 6 speeds, FWD and RWD.
Old Feb 13, 2012 | 12:06 AM
  #28
Part of it is a "ratio war" going on, if 5-speeds are good, 6 are better right. Now Porsche has a 7-speed manual, and we're seeing 8, 9, and 10-speed automatics in other brands.
If the there is a genuine performance or economy benefit to be had from more ratios, that's fine. But I think we're seeing a minor revival of what happened in the 60's when you had to have a "4 on the floor" to be considered cool, now you better have 6-speeds or more, otherwise you're behind the times.
Old Feb 13, 2012 | 01:58 AM
  #29
I agree with 843, Even new harleys have 6 speeds.. Even tho 6th gear is still a 1:1 ratio.. This is no benefit.. It's now a close ratio joke..
My 3 speed Flathead has a 1:1 trans ratio in 3rd gear....
Bert Baker of Baker Driveline has (DD7) 7 speed trannys, that have a true OD hi-gear..
Do they need all those gears. No, it's a "keep up with the jones" kinda thing.
Old Feb 13, 2012 | 06:15 AM
  #30
jsis7895's Avatar
i agree i thing if you have the extra gears you shoul make use of it.
