Accessing the Subwoofer and AMP
Old Jul 2, 2014 | 12:11 AM
datedd's Avatar
I want to add a new system to my SS and I need to know how to remove the back panel to access the Sub and AMP. I have looked everywhere on the procedure and I cannot find it.
If someone would provide me with a link to the procedure I would be grateful.
Thanks!
Old Jul 2, 2014 | 07:31 PM
07azhhr's Avatar
Take the load floor out. Remove the tray that covers the spare tire. Remove the storage bins that are behind the rear seats (3 10mm nuts). Remove the 2 left side floor tie downs. Remove the bottom plastic trim that is just inside the lift gate. Remove the upper trim just inside the lift gate. Remove the left side tie down that is on the verticle panel. Remove the upper bolt for the rear drivers side seat belt. You can now remove the upper panel above the lower side panel you are trying to get to. Now go thru the rear drivers door and unbolt the 2 18mm nuts for the drivers side rear seat bottom. Lift the seat bottom to reveal the lower bolt for the seat belt and remove that bolt. Remove the plastic rear rocker molding. Yo can now work out the lower panel. It won't be easy with the seat still installed but that seat is very very heavy and will be just as much of a pain as everything you just removed if not more just by itself.
LT1GMC
28
Nov 14, 2019 09:49 AM
tech-guy
Jul 7, 2010 05:45 PM
trickss
Jun 14, 2010 10:33 PM
SnoopHHR
Maintenance and Upkeep
Jan 6, 2009 09:44 AM
