Best Way to Convert 08 SS to Brembos
Old Nov 23, 2013 | 06:41 AM
cj krause's Avatar
i saw this
http://www.crateenginedepot.com/Brem...UK-P17436.aspx
is there a cheaper way to do it and where did you order it and the parts
i have been researching this
any help would be appreciated
Old Nov 23, 2013 | 07:04 AM
They are starting to show up at some parts stores as re-manufactured. Paul down in Portland built a set this way.
http://www.oreillyauto.com/site/c/se...HHR&vi=1442788
Old Nov 23, 2013 | 07:16 AM
cj krause's Avatar
i logged in and it worked
what all parts do you need?
it showed a page w allot of parts and none listed as Brembo
Cardone
Old Nov 23, 2013 | 07:32 AM
Yea, they can't represent them as brembos, notice all the pic's are of the back of the caliper..
All you really need is rotors and the caliper, I used the same brake line. I have a set of new brembo pads, let me know if you want them. I went with a set from the folks I bought the rotors from. http://brakeperformance.com/?gclid=C...FQF_hwodEVo-YA
Old Nov 23, 2013 | 08:14 AM
cj krause's Avatar
i will take them
let me know what you want for them and shipping
i am keeping the dimpled slotted rotors i have
Old Nov 23, 2013 | 09:25 AM
How does 1/2 price sound ? I think the brembo rotors are bigger by about a half inch. Correction it's almost a n inch. 12.42 and 11.64
Old Nov 23, 2013 | 03:54 PM
jczboy's Avatar
You are going to need the calipers, rotors hardware & pads. A slight bend at the top of the hose bracket and reuse the banjo bolts. I found all the parts I needed on eBay. (The SS Cobalt is the same) Cost me less the $500 for the whole project. Good luck.
Old Nov 23, 2013 | 05:21 PM
LT1GMC's Avatar
I bought New GM Brembo Calipers at RockAuto for $172 each, Raybestos rotors new from Rockauto for $36 each (painted), new GM Pads from dealer for $56, and the hardware kit from Rockauto for $17. Total $489 for all NEW parts. I have ordered the longer hoses from dealer for $24 each, will advise if they are much longer. I think the stock ones are too short for safe long term operation.
Old Nov 24, 2013 | 12:08 AM
lafinests213's Avatar
What the part number in the break lines and did they fit good?
Old Dec 7, 2013 | 08:48 PM
LT1GMC's Avatar
GM part number 25954272, they are 1.5" longer, have a 1.5" longer "insulator" piece on them, and are not stretched so tight on full turn. They come with banjo nut and copper washers. About $25 each.
mcmokc
Fuel Economy - Hypermiling
13
Aug 9, 2011 02:38 PM
tracksentinel
Mar 7, 2011 08:46 PM
got2boostit2
2.0L Performance Tech
Dec 22, 2010 03:04 PM
sethwas
"How To" Tutorial Library
15
Sep 10, 2009 11:26 PM
MikeX
May 22, 2006 01:32 PM
