Bleeding Master Cylinder & ABS
Old Sep 14, 2020 | 12:11 PM
tiapetra's Avatar
Originally Posted by tiapetra
Here is a cost effective pressure bleeder if you are into the DIY stuff. Of course scanner with abs capability helps too.
https://www.amazon.com/Motive-Produc...51780138&psc=1
They work very well
You have to be very gentle with the brake fluid so as not to create microscopic bubbles which will collect into larger ones in your system later on. Brake fluids are bad about that.
Comes in handy for refreshing the fluid every couple years.
Originally Posted by Oldblue
The Scan II tool is required for proper ABS bleeding of the brake fluid.
I bolded it for ya
Old Sep 14, 2020 | 12:38 PM
Thank you.
Old Oct 9, 2020 | 10:14 PM
Pretzel's Avatar
I just bought the Autel MAXI pro scanner. I have to bleed the ABS on my SSR. I will see if it supports the HHR ABS too.
Go to 10min mark on video.
Shisbey01
16
Sep 29, 2019 11:45 PM
fastsuv
10
Feb 20, 2019 05:38 PM
skuzzlebutt
Apr 18, 2014 01:18 PM
mjsz34
Sep 6, 2013 08:55 AM
JOEK86
Sep 16, 2006 05:25 PM
