Blown Head Gasket
Old Dec 20, 2008 | 02:47 PM
Dr_Jekyll's Avatar
Originally Posted by Little Red Wagon
It's a 79 Z28 (wife's car).I have a 62 Corvette.If you care to look I have pictures of both at the link below.
http://s35.photobucket.com/albums/d160/62f79/
I don't think I'll have any trouble with them so far they've pretty good.
My bad, thought it was an 80 or 81. Those are 2 very nice rides you have.
Old Dec 20, 2008 | 03:00 PM
Little Red Wagon's Avatar
Thanks,We did take the Camaro out today to the dealer to see what goes with the HHR.After Christmas I'll strip all the trim off Corvette and send it off to the local restoration shop for a complete paint stripping and have it painted in Dupont Hot Hues Candy Red with pot of gold base.
Old Dec 20, 2008 | 05:43 PM
mistermike's Avatar
I'm surprised to see boost hitting that high in an unmodified SS. Perhaps there was a failure in some aspect of the control system, allowing boost to rise abnormally high.
Old Dec 20, 2008 | 05:55 PM
The boost had been going too high for a few weeks,popping off before rpms got into the 4s.Sometimes it would lose all boost until you restarted the car.I just didn't have time to take it in.
My salesman said the mechanic hadn't got into it too much,but thought the turbo let go and must have pump antifreeze in one cylinder and blew an oil line.We'll find out Monday.
Old Dec 20, 2008 | 07:45 PM
MetallicaMatt's Avatar
wow
well if your goina go, go big!
Old Dec 21, 2008 | 08:04 AM
  #26
mistermike's Avatar
It sounds as if the wastegate / trim control was sticking on the hot side. If there was a cooling or oiling issue, this wouldn't be surprising. I'm using this nebulous description, because I'm not even sure if our KKK turbo has a conventional wastegate, or just the variable trim deal. I haven't spent much time under the hood. One thing to be careful of with a turbo failure if it spreads to the cold side, is metal debris from the turbo causing damage downstream, particularly to the intercooler. Although this type of failure is usually catastrophic, and about as subtle as an elephant's dong, it may be worth taking a peek at the plumbing directly after the turbo outlet and also at the inlet of the intercooler for signs of damage.
Old Dec 21, 2008 | 10:19 AM
  #27
Thanks Mike,I'll suggest that info to whoever calls me to let me know their progress.
This is only my second turbo charged car.My first was a 89 Caravan with a 2.5 turbo 5-speed in the four years and 75,000 miles we had only had a map sensor and 1st/2nd cynchronizer go out.
Old Dec 22, 2008 | 11:30 AM
  #28
jerSSey HHR's Avatar
Wow - that sucks - sorry to hear about this. I wonder how long it will take them to fix it? Are they giving you the Equinox as a free rental or do you have to pay for it?
Old Dec 22, 2008 | 11:41 AM
  #29
It's a free rental,GM pays for the Hertz car I pay for the gas.
Old Dec 23, 2008 | 11:26 AM
  #30
Up Date:
Just got a call from the tech, Melted one piston,they have the engine torn down so far parts needed new piston,new sleeve,new crank, and new rings.
They still don't what was causing too much boost before it had the revs to go with it.They'll have to wait until thay get it back together.
They won't get any parts until next week.
