boost numbers
boost numbers
heard alot of guys saying too low or too high. got problems .
the best i can do is 12psi with no problems
what is the number the computer is set up for. would like to hear what your worst or best is with no issues, good running hhr.
That's funny, I was thinking about this today on the way home from work. :)
The best I can do on city streets is about 10psi (70kpa for us Canadians).
Considering the guage goes up to 200kpa, is this OK?
For what it's worth, here is a PSI to KPA converter...
http://www.csgnetwork.com/presskpapsicvt.html
I may be wrong but from what I have read Boost will never be consistantly the same all the time.
It is computered controled based on Weather, Temps, Alt., and other factors. Because of this it should change based on conditions.
Some days I pull some good numbers and some days it is only 12-13 pounds.
Mine was a pretty consistant 15 PSI tops, but I was able to bump that up to about 17 PSI by adjusting the wastegate rod slightly. I didn't wan't to go all the way, but figured it was set pretty conservative from the factory...
