The Boost Spike corrected...
Old Mar 23, 2009 | 10:13 AM
Mr.Redface's Avatar
Are there any diagrams of which connections to check? Never had a turbo before and haven't opened the hood to do anything but clean it so far.
Old Mar 23, 2009 | 10:15 AM
gcsd3742's Avatar
check all of them. should be like 4
Old Mar 23, 2009 | 10:33 AM
Mr.Redface's Avatar
Thanks, So just the main connections.
I'll have to get familiar with whats under the hood I just ordered the replacement BOV spring.
Old Mar 23, 2009 | 12:14 PM
gcsd3742's Avatar
good deal you wont regret it. post up what you think after install maybe check the 1's on intercooler as well
Old Apr 13, 2009 | 06:56 AM
bad03xtreme's Avatar
Where is the tube that needs to be tightened going to the turbo?
I tightened both hoses coming out of the intercooler and the hose directly behind the airbox, are there more connections I need to check?
Old Apr 13, 2009 | 09:20 AM
Arne73's Avatar
Originally Posted by gcsd3742
yeppers, they get loose just like anything else, not suspose to but Newtons law comes into play
Murphy's law may apply as well.....
Old Apr 13, 2009 | 05:08 PM
millerrdjr's Avatar
Originally Posted by esmarkey
Update:
Tech "found leak at vacuum hose nipple on charged air pipe between IC and TB".
Replaced charged air pipe.
No more surging and have seen a consistant 22 lbs boost at full load.
Eric,
Has your boost stayed consistent?
Thanks,
Bob
Old Apr 13, 2009 | 05:09 PM
gcsd3742's Avatar
Of course but I see more than 22LBS. But you also have to know that I son't have the factory stuff and I also run H/P Tuners on top of the GM Stage 1
Old Apr 13, 2009 | 10:21 PM
hhrss09's Avatar
I just had the same problem. Low boost in 1st and would bog when launched on the launch controll. I just had the GM stage kit done and thought it was something they did. I didn't notice this before cause over the winter with the snow tires on it I would take it easy in the first 2 gears.I read on here about you guys and the boost hoses so I checked them. They were all loose. But the worse was the air intake from the air box to the turbo is was so loose I could move it by hand. I think it's time to get the Hahn intercooler and hoses:)
Thanks guys for the help finding the problem with the hoses.
Old Apr 14, 2009 | 09:23 AM
esmarkey's Avatar
Originally Posted by millerrdjr
Eric,
Thanks,
Bob
So far so good
There must have been a leak, because it is much more stable now.
