The Brake Fix Is In
Old Nov 2, 2009 | 04:12 PM
  #171
ChevyMgr's Avatar
Originally Posted by merlin
Has anyone had the brake fix done and are still having issues. I had it installed last week and even the Service Manager admitted that there is still an issue with the hard pedal on start up, not as bad (in his opinion). I have an '09 SS with the Stage 1 kit.
Merlin
They need to check with GM TAC to make sure they have installed the correct programming. Stage kit + pump equal different program than pump only.
Old Nov 2, 2009 | 04:28 PM
  #172
ChevyMgr's Avatar
Originally Posted by jerSSey HHR
I finally got a call from the dealer that all the parts are in. Now I've got to figure out when to get them installed.
Don't wait too long or they will sell it to someone else.
Old Nov 2, 2009 | 05:42 PM
  #173
hyperv6's Avatar
Yep at least set the date. Even if it a couple weeks out you will be on the books.
Old Nov 3, 2009 | 07:18 AM
  #174
WS6's Avatar
WS6
Originally Posted by WS6
Now been 5 weeks and no pump!!!
Got a call from the dealer last evening and have an appointment to install today.
Old Nov 3, 2009 | 08:16 AM
  #175
jerSSey HHR's Avatar
Very true - I will call today to set up an appointment. Thanks!
Old Nov 3, 2009 | 09:00 PM
  #176
dkessman's Avatar
I received an email today from the dealer that the PUMP is in! I set up an appointment for tomorrow morning. They said it will take about 4 hours to complete. I hope all goes as planned.
Old Nov 4, 2009 | 09:41 AM
  #177
WS6's Avatar
WS6
Had the brake fix installed yesterday. Took them six hours. The work order shows the following:
Installed 11518257: CLIP (04931-BPCK) Qty: 1
Installed 11570082: BOLT (08900-BOPCKT) Qty: 2
Installed 11588738: BOLT (08900-BOPCKT) Qty: 1
Installed 12177236: RELAY (09778-BOPCKT) Qty: 1
Installed 15319476: FUSE (08965-BOPCKT) Qty: 1
Installed 19115602: CONNECTOR (04820-PCKT) Qty: 1
Installed 20804130: PUMP (04895-PCKT) Qty: 1
Installed 20815216: BRACKET (04805-C) Qty: 1
Installed 20817629: HOSE (04931-C) Qty: 1
Installed 20817688: INSULATOR (04805-C) Qty: 1
Installed 3530297: NUT_AIR I (08917-BOPCKT) Qty: 2
Installed 88988583 CONNECTOR (03682-BPCKT) Qty: 1
INSTALLED VACUUM PUMP RETROFIT KIT, REPROGRAM
BULLETIN 09052201A
Started the car this morning and still took about 2 mins. to build up 20lbs. vacumn.
Old Nov 4, 2009 | 10:01 AM
  #178
REDHHRSS's Avatar
But you had brakes right?
Pat
Old Nov 4, 2009 | 12:18 PM
  #179
WS6's Avatar
WS6
Pat
Better, but not up to what I wanted. Rear brakes grinding gone.
Old Nov 4, 2009 | 03:17 PM
  #180
merlin's Avatar
Checked with the service manager and they did get the correct program. He indicated that he had another that was also not providing good brake pedal and it did not have the stage kit, so they were going to do some more investigation. Will update when I know more.
