Clutch smell
Old Jul 11, 2008 | 08:19 AM
Retro1949's Avatar
Clutch smell
This is my first post (actually technically my second as I just replied to the transmission noises thread). I am the recent proud owner of a 5 speed black SS, probably the only one in Newfoundland, Canada. My satisfaction rating with this vehicle is about 80% but one issue concerns me. I'm getting a burning clutch smell on occasion. It has happened 2-3 times when revving the engine and slowly releasing the clutch when backing up an incline. Any remedy for this and can 1 or 2 severe occasions permanently damage the clutch? Thanks!
Old Jul 11, 2008 | 08:44 AM
405HP_Z06's Avatar
If you slip the clutch excessively, this is normal. To prevent this, don't slip the clutch; get on and then off quickly. A few instances of minor clutch slip won't hurt the clutch. Now, if you do this on a regular basis you will shorten clutch disc life and potentially warp the flywheel.
Old Jul 11, 2008 | 09:11 AM
astropods's Avatar
They tend to be a little smelly when they're breaking in anyway. You didn't damage it but the more kind you are to it the longer it will last (obviously).
Old Jul 11, 2008 | 09:46 AM
Canuck's Avatar
Absolutely correct, called "riding"" the clutch. When the clutch isn't FULLY engaged or released for any period, the turning fly wheel (from the engine reving) rubs (slips) against it causing the burning and the resulting smell.
Congratulations on your purchase BTW. What colour is it?
Old Jul 11, 2008 | 12:22 PM
jerSSey HHR's Avatar
Originally Posted by Canuck
What colour is it?
his post indicated black
Old Jul 23, 2008 | 12:15 PM
Retro1949's Avatar
Thanks for the replies. Seems like I should refine my driving techniques, especially when backing up on hills. A heavier duty clutch, however, would have been nice from GM.
Old Jul 23, 2008 | 01:59 PM
cperez1217's Avatar
yeah dont do that to often because you will glaze the clutch and will need to replace cuase it will slip after that
Old Jul 23, 2008 | 02:21 PM
Canuck's Avatar
Duh - if only I could read
Old Jul 23, 2008 | 03:53 PM
an08HHR's Avatar
Don't rev the engine. only need to give it slight gas and let out the clutch completely
Old Jul 23, 2008 | 05:07 PM
No wild smokey burnouts in reverse? That's what my wife tells me happened to her when she tried to learn how to drive a stick when she was younger.
