Cold Weather Issues
I would agree the gas compresses in cold weather, but these products should be designed to function at -20 C (typical automotive standard), and even at -40 C (extreme standard for automotive). So for it not to function even at 40 C, I was wondering if I had a bad shock or if it was a poor design from the General.
Check out this video and see if it sounds like noise #3:
http://s735.photobucket.com/albums/w...t=MOV02237.flv
If so, it took several trips to the dealer to get it fixed. It only happened when it was cold and by the time I got it to the dealer the interior was warm and no noise... They even kept it overnight to see if they could hear it after it sat all night, but stored it indoors..... DUH! Again, no problem found. Finally I made the attached video and one of the techs dug around and found it.... If it is the same sound, I can pull out my old service records and see if they list the fix.
Let me know.
Let me know.
Ironically, the noise gets quieter as the radio volume goes up!
the "general" doesn't design the struts. lots of parts from lots of outside vendors.
i work for any extended warranty co. for 8 yrs. if you think this car is cheap, try a honda civic, where the front suspension struts leak every 15k miles. that car also has a technical service bullitin from 2006-2008 for engine blocks cracking at the waterjackets cracking at 5 different locations causing the engine to overheat - needs new engine. also another bullitin that states to replace the rear control arms because the geomotry is wrong causing the rear tires to wear out real fast.
What the hell is that? Are you pulling your parking brake while driving, 'cause that is what is sounds like. Mine sounds more like the speedo needle (if it would be made of metal) is vibrating. It is cold in Detroit today, so I will see if it make the noise after work.
