Did my Aeroforce Gauge now
Old Sep 30, 2008 | 04:46 PM
gcsd3742's Avatar
Wow what a difference, GM should have their heads examined there is nothing to compare between the Turbo Boost gauge and the Aeroforce Gauge. The top is the H/P and the bottom is Turbo Boost. There are 24+ settings on this gauge so get yourself one as well. It bolts right in and plugs in. Had it done in 4 minutes. start to finish.
Last edited by HillsdaleHHR; Sep 30, 2008 at 10:12 PM. Reason: Reduced pic sizes/ 1st Warning Given
Old Sep 30, 2008 | 05:10 PM
Dr_Jekyll's Avatar
That's pretty cool, where and how much. :) How do you get the stock gauge out?
Old Sep 30, 2008 | 05:11 PM
foolmoon_design's Avatar
Ditto, I know ADM has em.... how is the install?
Old Sep 30, 2008 | 05:34 PM
gcsd3742's Avatar
The install was a breeze. 1 bolt under the airbag sign. use a small screwdriver to remove that then undo the bolt 7mm. then pull on A-piilar in pulls right off. then unplug the 2 plugs 1's for the gauge the other is the Tweeter. undo the 2 nuts off the back of the gauge it slides right out of the hole. The gauge in return goes right into place. then run the 5' wire down and plug it in reverse the steps your finished. It was that easy. I got mine from Stylin Concepts I used their discount of I believe it was 20% at the time. but here are others that you can order from right off their site: All I can say is WOW what a difference between the 2.
http://www.aeroforcetech.com/dealers.html
Old Sep 30, 2008 | 06:29 PM
camaro98z28's Avatar
Horsepower at the top? How does it do that?
Old Sep 30, 2008 | 09:38 PM
gcsd3742's Avatar
It puts it upon throttle responce. It's actually pretty cool gauge I highly recommend it.
Old Oct 1, 2008 | 02:36 AM
08BlkSS's Avatar
Thats sweet! definately something to look into, is there a different link, the one you posted isnt working for me...
Old Oct 1, 2008 | 06:10 AM
Chevy SS's Avatar
How accurate is the HP reading? Has it been compared to a dyno? Does it measure engine hp or calculate wheel hp?
Old Oct 1, 2008 | 06:19 AM
ADM PERFORMANCE's Avatar
Former Sponsor
We sell a ton of them.
I will work on a coupon for hhr ss guys...Sound good?
Old Oct 1, 2008 | 07:01 AM
gcsd3742's Avatar
than go down to dealers. I used like I said Stylin Concepts. they have coupons all the time. I got 20% off my order over $100.00
