Did my Aeroforce Gauge now
Those lights can be programmed to do just about anything, from shift lights to warnings when engine parameters get out of spec. I've got one of these on order.
As you saw with the blink of an eye yes those are lights for warning or shift lights alot of charateristics go into them....I am really enjoying this gauge. GM should look into these vs. the crap the installed
http://www.aeroforcetech.com/
than go down to dealers. I used like I said Stylin Concepts. they have coupons all the time. I got 20% off my order over $100.00
all I can say is to google aeroforce gauges then. GM should change out all the gauges to these they are so much more useful and can even read the OBD 2 codes and clear them if need be + 20 or more functions. It should work on auto or standard. If your worriede about warranty what warranty its a gauge. If anything it will warranty out just the gauge big deal this gauge works so much beter an more precise than an analog gauge. Here you go heres what your looking for I assume
Man if I could sale this to GM what a better gauge this is...It should be an option.
http://www.aeroforcetech.com/Redline_Cobalt_tech.html
* RPM
* MPH
* Intake Air Temperature pre intercooler
* Intake Air Temperature post Intercooler *
* Mass Air Flow Sensor Frequency *
* Mass Air Flow Sensor (lb/min.)
* Engine Coolant Temperature
* Injector Pulse Width
* Long Term Fuel Trim
* Short Term Fuel Trim
* O2 Sensor Voltage
* Manifold Pressure in PSI (Boost pressure)
* Supercharger Inlet Pressure *
* Ignition Advance
* Knock Retard *
* Engine Run Time
* Battery Voltage
* Throttle Position Percentage
* Engine Load
* Instantaneous fuel economy
* Horsepower
* Analog input #1
* Analog input #2
Just a few of the things it can do...
* RPM
* MPH
* O2 Sensor Voltage
* Ignition Advance
* Knock Retard *
* Engine Run Time
* Battery Voltage
* Engine Load
* Horsepower
* Analog input #1
* Analog input #2
