Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Dumb Comment & Question About Gas Type (https://www.chevyhhr.net/forums/hhr-ss-45/dumb-comment-question-about-gas-type-64354/)
ibenzawla Jun 6, 2021 04:42 AM
[QUOTE=firemangeorge;911469]No. He was talking about this Bosch sensor (red circle). It's called a Tmap sensor.
Doesn't seem to have that. I posted pics above.
rorr Jun 6, 2021 03:30 PM
Originally Posted by ibenzawla (Post 911437)
Okay will check and post the result. I have no idea but will check. I truly love my SS and it runs well besides the occasional sluggishness. I think it may just need some proper tune up. Currently it has the stock air filter and I heard that something like K&N can help but I also heard that the oil on the filter can be an issue.
This is my experience, so take it for what it's worth. Mine is an '09 Manual SS.
When I first got mine, I thought it was pretty sluggish occasionally as well. But, I soon figured out it was only after making a sharp turn above 10 to 12 mph. Like pulling out in front of cars from a gas station. I was all "giddy up man!", but it would take 2 to 3 seconds to have full power. I had a hunch it was GM Nanny Patrol, so I started driving around in competition mode (traction control off, but stability control still active) and I'll be darned, no more sluggishness after tight turns. So, maybe what you're noticing is just the way the ECU is programmed?
Just a thought. I'd hate for you to go chasing a problem that isn't there.
Robert
terryk Jun 6, 2021 05:14 PM
I have the GM Turbo Upgrade so keep that in mind.
I had to run 87 octane once when I couldn't get 91+ on a trip. I had maybe 2 gallons of 91 left and filled up. Normal cruise and driving around you couldn't tell the difference. I would assume my MPG might have been slightly better due to the lower octane but I can't say I noticed anything. High octane burns slower and will generally result in lower MPG. Now rolling into just about any boost above about 10psi, it would flatten out pretty quick as the knock sensor pulled timing. I didn't check as to how much boost I was actually getting but it felt sluggish enough that I stopped checking. It wasn't jerky or missing, it just limited the power. I never heard any knock. I just need to cruise and pass people for a couple of hours and it otherwise ran fine. I refilled with 91 when it was available.
As far as 91 vs 93, I can feel a very subtle difference *sometimes*. It's mainly at WOT. You can feel it slightly pull back on 91 *sometimes*. On 93 it doesn't seem to but again, it's not dramatic. It's one of those "yeah, I think maybe I can feel a difference." I wouldn't give a second thought to running 87 again if necessary.
I also don't notice any real difference between traction modes but I rarely try four wheel drifts. I've never done a Launch Control or no-lift shifts.
YMMV
donbrew Jun 6, 2021 05:43 PM
I must live on a different planet. I have always got a few extra mpgs from higher octane fuel; the problem is the cost/benefit. You pay more per mile even though you are getting more miles to the gallon. It is different at some times when 91 is only a few cents more that 86.
Octane has nothing to do with "burns slower"; it is a measure of how much pressure the fuel can take before it spontaneously combusts (dieseling/preignition/knocking).
https://www.eia.gov/energyexplained/...e-in-depth.php
terryk Jun 6, 2021 06:54 PM
It's all part of the same effect. Yes, resisting pre-ignition is part of it. But if you get better mileage, yes, definitely run higher octane gas.I consider it a waste of money scientifically.
donbrew Jun 6, 2021 08:31 PM
Isn't that what I said? Better MPG worse $/mile.
However, when it comes to turbocharged, there is a higher internal pressure so you need the higher octane to resist "dieseling". AND we are talking about a SS.
ibenzawla Jun 7, 2021 03:05 PM
Robert
Yes its a bit strange when I first test drove it just down the road. I was left wanting more but knew it had a lot of potential. I call it the reluctant SS. Driving around town it feels like it is reluctant to show it's power but when needed it can really go. I am a safe driver but a few times someone wants to try me and I am yet to loose. The SS yet to let me down. Appreciate your input. BTW I have hard about the Launch Control but never tried it.
ibenzawla Jun 7, 2021 03:20 PM
YMMV
Thanks for your input. Considering my little knowledge about cars I will mostly stay with 91 or 93 but if I have to use 87 or 89 then I will not be that worried at least in the short to medium term. I would make sure to use octane booster (someone suggested to me here) once a while. I have learned a lot on this forum and I am glad I asked this question. I love the SS so much that I try my best to baby it.
Cokeybill Jun 9, 2021 04:48 AM
https://cimg1.ibsrv.net/gimg/www.che...bb489a3d8b.jpg
Thanks Fireman. I couldn't take a pic because I sssssssold it. I can't even say it now. :bye:
