Fixed my low boost problem
I took my HHR SS to the dealership and they wouldn't fix it so I came to the fourm and some of you were talking about waste gate mod so I tried it and it brought my boost back up to 20 psi and it builds like it did when it was new I believe that the springs in the waste gate gets weak and adjusting it Fixed mine.
here's a how-to even though this is not specific for our vehicles its a general idea. there is a nut that you back off and then adjust the rod as jeff was saying below in his post... DON'T CUT IT.....
http://images.google.com/images?q=ad...num=1&ct=title
Jeff it was a simple how to..If you follow the link it will lead you to other things as well...It was a simple help to the issue that is all....LOL
http://www.solsticeforum.com/forum/f...ate-mod-40031/
And yes it does have a nut you just back it off.
all i did was to adjust (shorten) the adjustment there are two nuts one on ether side of the waste gate arm I shorten it as short as I could which places more pressure on the waste gate and keep it closed tighter and if your car isn't setting any codes the dealership I took it to wouldn't look at it, they drove it and said it has a lot of power there is nothing wrong with it.
Eric, yeah I did see all those google images, and followed one to a sky forum, but it was too early in the morning to think about such stuff. Suffice to say short rod = more boost, long rod = less boost.
Defies logic eh?
Defies logic eh?
