Gear ratios / RPM @65Mph
Do 5 speed trans have higher MPH than automatics if so why?
What is the rpm at 65mph manual trans fifth gear?
what is the rpm with Automatics?
I heard trans gear ratio and diff ratios changed with the turbos compare to non turbo,
what is the trans and diff gear ratio, 1 thu 5th and 1 thu 4th automatics
