Gear ratios / RPM @65Mph
Old Dec 16, 2008 | 01:20 PM
Ratracer's Avatar
Originally Posted by cannuck
at what mph does the auto shift for each gear at normal acceleration occur
I know that it shifts 3rd to 4th at about 47mph. My rural drive is @ 45mph, but I ease up the speed to get it to shift into 4th, to knock off RPM's for a little fuel conservation.
Old Dec 16, 2008 | 01:34 PM
ChevyMgr's Avatar
There really is no normal speed for the shifts. Lot's of data is sent and received by sensors and the transmission control module based on fluid pressures, ambient/trans/engine temperatures, load and others. If the auto transmission isn't shifting correctly your Check Engine Light will come on and set a code.
Old Dec 16, 2008 | 08:40 PM
c2vette's Avatar
Originally Posted by Nebulous1
Are you sure those are the correct numbers? Check out http://media.gm.com/us/powertrain/en...08/08truck.htm. Check out the spec sheets for the LNF's transmissions, both 4T45(MN5) and F35(MU3).
4T45/MN5 shows:
First: 2.96
Second: 1.62
Third: 1.00
Fourth: 0.68
Reverse: 2.14
Final Drive Ratio: 3.05, 3.29
F35/MU3 shows:
Gear ratios: MU3
First: 3.38
Second: 1.76
Third: 1.18
Fourth: 0.89
Fifth: 0.7
Reverse: 3.17
Final Drive Ratio: HHR SS - 4.05
I could not find the relevant thread, but some time back it was indicated that some of the ratios on that site are apparently incorrect.
Old Dec 17, 2008 | 11:55 AM
LT1GMC's Avatar
Originally Posted by XXL
Like I did in my post above?
La Machine.
Your post did not show how you got the second number, that you multiplied the final drive by the gear ratio, I explained it so others would understand.
skyline26
Sep 9, 2013 03:34 PM
bad03xtreme
Aug 14, 2009 07:03 PM
camaro98z28
2.0L Performance Tech
Sep 28, 2008 10:31 PM
NYBLKBEAUTY
Feb 29, 2008 09:57 PM
cj krause
Aug 16, 2006 10:17 PM
