Gear ratios / RPM @65Mph
Do 5 speed trans have higher MPH than automatics if so why?
What is the rpm at 65mph manual trans fifth gear? what is the rpm with Automatics? I heard trans gear ratio and diff ratios changed with the turbos compare to non turbo, what is the trans and diff gear ratio, 1 thu 5th and 1 thu 4th automatics |
Can't tell you about the auto, but here is the gears for the SS manual:
1st = 3.38 2nd = 1.76 3rd = 1.18 4th = 0.89 5th = 0.07 Final drive ratio = 4.05:1 |
Originally Posted by tony326
(Post 336232)
Can someone post the gear ratios for the auto so we can compare?
Auto Ratios
1st-2.96
2nd-1.62 3rd- 1.00 4th- .68 Final 3.63:1 |
Thanks ratracer, I thought the auto may have a shorter final drive.
Correction- Final drive is 3.29:1 , 3.63:1 is non-SS tranny
No wonder this thing likes to cruise @ 80:eek: |
That's what I was thinking. There is quite a difference between the auto and manual!
can you change ring and pinon gear ratios 4.05 to 3.63 on manuals
can you add posi to automatics by swaping spool? |
And here I thought the SS ratio on my 08 was somewhere like 417 to 1......
| All times are GMT -5. The time now is 06:41 AM. |
