GMTU Boost fluctuations
Old Feb 15, 2014 | 12:02 PM
They are available remanufactured from some part stores now....much less money to switch them than it was.
Old Feb 15, 2014 | 12:03 PM
Gotta agree with Sam on that. Good performance plus they look good.
Attachment 15807
Old Feb 15, 2014 | 05:19 PM
frdfandc's Avatar
Originally Posted by eaglefreak138
Hmm. Is that all points of mph when you go Wot? You should see over 20 at times especially below 40mph or between 50-70mph
It may quickly flare higher, but I don't see it on the boost gauge.
I've checked over everything - Map sensor contact with the A/C compressor, all wires are soldered - may have to revisit that once it gets warmer and re-do them, checked for boost leakdown.
Going to switch out the yellow spring for the green spring next. If that doesn't work then I'm planning getting it tuned via HPTuners.
Old Feb 15, 2014 | 05:33 PM
Our group is planning on that this spring also. Sure there will be a learning curve but with 6 SS's in the group, shouldn't take too long to dial them in...
Maybe 7 hey Paul you wanta tune that thing yet ?
Old Feb 15, 2014 | 08:59 PM
paulBvtn's Avatar
You forget Sam, I *am* tuned with Trifecta. And pretty happy with it too!
Old Feb 15, 2014 | 09:07 PM
Sorry man getting old CRS.
Old Feb 16, 2014 | 10:33 AM
Let's just say if you gave Vince, or GM your money there is..
Of course I have both........
Still haven't bought the suite.
Old Feb 17, 2014 | 08:46 AM
fiveothis's Avatar
That's what I'm thinking. I haven't noticed it in "i" mode. Man, this tune has awoke since the faulty charge pipe was replaced. If this GMTU is fun I can't wait to try Trifecta when my warranty is up.
What do you mean by "I" mode??
Old Feb 17, 2014 | 08:51 AM
eaglefreak138's Avatar
Popped the yellow spring in to see if that helps the mid range throttle occasional bouncing. Test drive gave me 25lbs with no flutter from a 60mph roll, 23lbs no flutter from a 40mph roll and reduced fluctuating while accelerating from a light with mid throttle. No flutter at any poiny and no CEL yet (knock on wood). Mine may be liking the yellow.
Old Feb 21, 2014 | 08:31 PM
bigjacksauto's Avatar
I am in the process of learning the hptunes.
Should be running a hptune early spring myself hopefully.
