H/P Tuners and the SS
What is your serial number eric? I have an update that adds HHR SS 2.0t support.
William Henn HP Tuners LLC. www.hptuners.com It's official H/P Tuners is now supporting the HHR/SS and the tune will be going into my HHR on the 11th...Bill is saying roughly 30 extra horses just from the tune and this is just the beta version...More to come :thumb: Thanks Bill |
Can you explain what you have to buy to get this 30 extra ponies?
Have someone hook up the H/P Tuners computer tuning software to it and reflash the ECM....www.hptuners.com to buy it yourself its roughly $700 to tune it 1/2 the price...
Someone? Meaning a performance shop or who? Any list of who would be able to do just the tune???
Originally Posted by gcsd3742
(Post 243677)
You've got to be able to know a tuner in your area..I know of 4 here in Houston area 3 of them do mail order tunes but then you'd be W/O a vehicle for a couple of days.....Wheatley tuning,Nelson Tuning, And T3 Tuning is the one im going to use....
(Post 243755)
Just popped the email over to support with my log, hopefully I can have a new version by the weekend and can toss it on the dyno Sat :):bow: |
Originally Posted by HHR_SS_Rocks
(Post 243759)
I dont need to know a tuner, just a version that can write the pcm, right now the currentl version cant support the hhr, it reads it as a solstice and cannot modify the stock base tune because of that.
Just popped the email over to support with my log, hopefully I can have a new version by the weekend and can toss it on the dyno Sat :):bow: We have posted an update on your customer login page located at www.hptuners.com This update adds support for the 08' HHR SS 2.0t for which you previously contacted support Please Download & install this new version at your earliest convenience. If you run into an issue while using this beta version please make support@hptuners.com your first point of contact. William Henn HP Tuners LLC. www.hptuners.com |
(Post 243759)
Just popped the email over to support with my log, hopefully I can have a new version by the weekend and can toss it on the dyno Sat :):bow: versions of 2.1 beta are the same. The versions dated after 2/29/08 WILL WRITE to the pcm as well as reading them. If you plan to try and increase boost, you can't do it with HPT yet. You can change PE's to richen things up but u have to do others mods to increase boost. There is a wgate mod but it tends to get unlearned. Taking boost control away from the ecm is the only way so far to get an increased and flat boost curve until HPT supports that idea of the code. turbofreak |
What about the torque limitation? I thought that was the primary issue, that somehow the torque was capped.
| All times are GMT -5. The time now is 04:36 AM. |
