Has anyone done polyurethane trany mounts?
I am thinking about replacing the stock trany mount inserts with polyurethane inserts. i would like a more solid motor but i dont want to go solid mount. im just wondering if anyone has done it or if any one has any other ideas..?
I just bought new stockers from Crate engine depot. I thought about going with a firmer aftermarket mount, but there have been some coments about increased vibration and I just drive too far to put up with that. Plus over the long haul it might rattle stuff loose. I know the guys that built mine the torque specs were optional... lol
There was a thread about using a Cobalt TTR insert in the stock mount and it sounded like it worked. I emailed TTR to confirm and they said a user did it, but they cant endorese using them, and I wasnt taking the risk. |
http://www.turbotechracing.com/produ...dcategory=5615
This little gem... TTR woudnt confirm the size but thought they "might" be the same. |
Originally Posted by ChevyGuySS
(Post 664817)
True solid would be horrable, we dont sell such a product. Next get the "STOP rotated tranny mounts" we carry. They are a direct replacement. We sell many of these setups each day. :twothumbs: |
Originally Posted by BZERKED
(Post 665005)
This little gem... TTR woudnt confirm the size but thought they "might" be the same. STOP tranny mounts fir the HHR SS Turbo |
I"ve been running the TTR upper mount for a couple of years now, and the vibs are barley noticable, and will not cause problems. Go ahead and get the TTR upper mount. Makes the power more managable, and weel worth it. "Moon"
1 Attachment(s)
Originally Posted by TurboTechRacing
(Post 665006)
Get our Upper engine mount... It is not what you are thinking of "solid" (metal on metal)... But it is much more rigid than stock, it does have a poly bushing in there.
I wouldn't leave home with out it. :twothumbs:
(Post 665077)
so its not really solid but just firmer? i am getting a lot of wheel hop and need something to cut it down a bit
Solid is a term that can be used here, as the stock is floppy! Solid does not mean metal on metal, it means rigid, or firm, or little to no movement. |
| All times are GMT -5. The time now is 04:33 AM. |
