I want to add an oil pressure gauge
When I read the threads looking for this information, the consensus seemed to be that oil pressure is not a good indicator of oil level. But if you really want to monitor oil pressure, I would think that you could do so from the OBD2 port.
So GM did not make it standard protocol to be able to pull oil pressure readings from the OBD system (or so I read).
Anyhow, it seems there is a workaround for this thru the Torque app. You have to program in a new setting in Torque to display and read oil pressure.
I have successfully installed these changes to the Torque program on my old phone. I’ll try it out in the morning and let you know if it works.
Disclaimer here: I’m not a computer guy. The Torque app even gave a strong warning about changing any values on their app. If it blows up my old phone…..well……..
I think GM figure out a long time ago that a gage is pointless. For one thing, it can only tell you what the pressure is where the sensor is, and the actual pressure thoughout the system is highly variable. So, oil pressure where?
OP has bigger fish to fry and should fuggetabout the oil pressure gage. By the time you notice it's low, it's too late. The light activated by a switch is more effective at protecting the engine from low oil. Also, check the oil every time you fuel.
Oil pressure doesn't have anything to do with oil level. Your plan would measure AIR pressure under the valve cover.
In modern engines it can help monitor the health of the oil. As oil is used it loses some of it's viscosity properties, thus lowering the oil pressure. But you have your OilLifeMonitor for that.
In race cars the oil pressure gives a clue to the health of the external oil pump.
In other words: Oil pressure doesn't mean anything to the average driver.
You can indeed read the oil pressure with an OBD-II scanner. It will read zero. Always. Pretty sure there is no quantitative oil pressure sensor, only a switch preset for a specific low pressure threshold. Other than that, the system has no idea what the oil pressure is.
