Inner crankshaft sprocket gm 55557168 or gm 12462713
Old Oct 18, 2019 | 11:36 AM
Jit's Avatar
Jit
Hello. Does anyone have one of these they would like to sell that is new? I'm trying to put my car back together and can't source one due to the strike. If you do please message me thanks a lot
It is the inner sprocket for 2.0 with VVT.
Thanka again. John
Old Oct 18, 2019 | 01:04 PM
5557168 superseded to 12789018, possibly on a Saab supplier site.
12462713 doesn’t show up as a GM part number.
Old Oct 18, 2019 | 02:42 PM
The inner sprocket, for the balance shaft chain. For the 2.0
90537301
The other sprocket, for the timing set.
24424758
I think the 2.2 and 2.4 use the same.
Old Oct 18, 2019 | 02:54 PM
Jit's Avatar
Jit
Thanks for the replies.
I think 90537301 is for non vvt based upon images. That looks like the one that came in my kit from cloyes.
my car has the vvt sprocket. It has 55557168 on it.
here are two sites that list 12642713 as a superseded number. Now im not sure as old blue has anorher number.
i really dont want to reuse mine as it has 160k of wear. Especially since i have replaced so many other parts.
cant afford to keep waiting for gm strike to end while paying for rental car for last 3 weeks.
so if antone has one on a shelh please let me know
Old Oct 18, 2019 | 04:39 PM
Is there visible wear? If not, drink an adult beverage and relax.
Old Oct 18, 2019 | 05:18 PM
I’ve reused then crankshaft sprocket for the balance shaft chain , no issues.
I don’t recommend reusing the timing chain crankshaft sprocket.
It's for VVT.
#174 in this drawing
https://www.wholesalegmpartsonline.c...ssembly=366334
Old Oct 18, 2019 | 05:26 PM
Which kit did you purchase from Cloyes
this RockAuto page shows the inner ( balance shaft chain and outer timing chain crank sprocket) part numbers for the 2.0
https://www.rockauto.com/en/catalog/...+sprocket,5723
Old Oct 18, 2019 | 06:15 PM
Jit's Avatar
Jit
Hello I bought the 9 - 4201 sa and the 9 - 4202s but the sprocket the set includes is not for the turbo engine with the VVT there is a sprocket but not for that engine. I confirmed that with cloyes technical support.
Also i might have used wrong terminology it is the balance sprocket on the crankshaft. It runs the water pump.
Yes Don Sounds like a great idea! I do have wear on lower edge of every second tooth. Not extreme and probably fine to use. Heck it has to be five o'clock somewhere..time for that beverage....
Old Oct 18, 2019 | 06:24 PM
Jit's Avatar
Jit
That diagram with 174 sure looks like the vvt. RJ SS
Here is a picture of my sprocket 55557168
I wonder how many different part numbers ther are for this sprocket.
Thanks again everyone for your help
pyro panel
Canadian Mid East
0
Jul 6, 2010 12:45 PM
urbexHHR
Nov 19, 2009 08:19 AM
rski
Jun 13, 2009 11:11 PM
RoadDawg831
Apr 13, 2009 10:02 AM
joesblackhhr
Sep 27, 2006 04:03 PM
