Key fob programming
Old Feb 6, 2022 | 09:22 AM
I thought the Dorman fobs won’t work for the TPMS match procedure.
Old Feb 6, 2022 | 10:39 AM
The Dorman programmer works with OEM fobs also.
Old Feb 6, 2022 | 11:00 AM
Some of the included fobs are trash. It seems that the one with a LED on the board don't do the TPMS and maybe RVS, and some send false low battery signal.
I always suggest to buy a Genuine remote to go with the Dorman kit.
Old Feb 6, 2022 | 11:54 AM
Got it, thanks Don and RJ.
Old Aug 3, 2022 | 08:53 PM
HHRjim's Avatar
HHR key fob programming
I have replacement fobs from a junk 2011 HHR LT and want to program them to work on my 2011 HHR LS.
IS this something I can do myself or does the procedure require special tool or skills?
Old Aug 3, 2022 | 09:55 PM
Maybe post good pictures, Front and back. Then we can help you figure out if they're OE or aftermarket.
Old Aug 3, 2022 | 10:06 PM
Short answer : not a DIY job no matter what the interwebs want you to think.
Old Aug 4, 2022 | 07:15 AM
A GM dealer or a locksmith, or that Dorman programmer should address that.
You can have up to 4 fobs to one HHR follow the directions on the instruction page
Old Aug 4, 2022 | 07:47 AM
That is 4 ever, the memory must be erased if 4 have already been programmed by previous owners.
Old Aug 4, 2022 | 09:13 AM
Right and don’t the instructions indicate or explain that?
