Lsd rpo
Old Jun 11, 2015 | 02:20 PM
dooscoop32's Avatar
Lsd rpo
Can anyone please supply the RPO code for the Limited Slip Differential option for a 2008 SS?
Also, does anyone have a complete up-to-date list of the RPO codes for a 2008 SS built in March 2008? I have found two such lists on this site but they seem to conflict with each other and both do not contain all the codes that are listed on the Service Parts Identification sticker in the glove box.
Thanks for any help you can provide.
Old Jun 11, 2015 | 05:17 PM
https://www.chevyhhr.net/forums/gene...options-12674/
Old Jun 12, 2015 | 02:48 AM
prod's Avatar
The lsd is code g85
Old Jun 12, 2015 | 07:52 AM
dooscoop32's Avatar
Originally Posted by prod
The lsd is code g85
Thank you, prod.
Old Jun 12, 2015 | 09:20 AM
Hey dooscoop32.
You said there were 2 different RPO lists on this site ?
Fwiw. I've done a lot of looking and deceiphering of the RPO codes before. Used that link above and some Google searching.
Generally, RPO code numbers just carry over year to year. New items get added, no longer used ones get deleted from the next list.
On my 2010 SS, I used the link donbrew noted. I just went through all the years and eventually found all but 1 or 2 listed for mine.
Some of those I did find, even with the description I wasn't quite sure what it was.
Old Jun 12, 2015 | 09:35 AM
dooscoop32's Avatar
Hey dooscoop32.
Well I assume they were different lists. There were two lists and they had different RPOs listed from one to another. Am I wrong?
Old Jun 12, 2015 | 12:16 PM
Not sure. The only list I was aware of was the one donbrew linked above.
Do you have a link to that other list ?
Old Jun 12, 2015 | 03:19 PM
dooscoop32's Avatar
Please forgive my ignorance. The first list was for the 2007 models. The second was 2008. I feel so incompetent.
Old Jun 12, 2015 | 06:02 PM
Doesn't really matter. The designation does not change. G85 means the same thing in 2006 as it does in 2015.
