Mod referrals?!
Old Aug 27, 2012 | 04:26 PM
MIKEYfixit's Avatar
Originally Posted by 2005HHRauto
Not really
Just punch out the cat guts in the 2th cat.
Than slide a piece of perforated 2.75" tubing into the back of
this stock downpipe, tack in place, & your done.
Better torque, under the curve, this way.
Looks stock, & passes emissions too.
Add a K&N intake, some corn whiskey,(E47.5), some traction, &
Your set to run 12's at the track.
I'd like to learn more about this, sounds like my kind of cheap mod. what did you use to punch the guts out? why the need for the perforated pipe? wouldn't this obstruct flow a little?
Old Aug 27, 2012 | 08:30 PM
2005HHRauto's Avatar
Actually I bought a SS muffler, then cut out the 2.75" perforated tubing, inside the SS muffler.
The automatic muffler has twice the perforation, then the manual muffler.
Either will work fine.
I then placed it in the back of the stock downpipe.
By hand, I turned it back & forth a few inches, while putting some pressure,
on the tubing, while turning it.
After about 15 minutes, I bored a nice 2.75" hole thru the cat.
This way you still have cat guts in place, when you put the empty,
tubing back in place.
After knocking out the 2.75" cat 'core', that's stuck inside the tubing, I slid it back
into the back of the downpipe.
I then marked it, & trimmed it flush to the back of the downpipe.
I tack welded it in place.
If you can't tack it, just drill & tap ,for one screw, to hold it in place.
This is only to prevent any rattling.
When your done, what's left of the 2nd cat, will still heat up, be very
Hot, when you touch it, or if any emissions guy touches it, to check for
Cat operation.
The perforated tubing is just to allow hot air to heat the remaining cat,
& the tubing holds this remaining cat guts in place, very well.
This mod removes the restriction of the 2nd cat, & still keeps it working.
The large, 1st cat is needed, to keep the torque up, & it flows well.
Aftermarket catless, or the ones with a small cat, hurts torque.
Yes, I've tryed aftermarket downpipes, with, & without the small cat.
The stock downpipe, with the 2nd cat restriction removed, works best.
Old Aug 27, 2012 | 10:47 PM
XtremeSS's Avatar
Specifics please.... What's considered a small cat? Which catted DPs have u tried?
Old Aug 28, 2012 | 06:16 AM
MIKEYfixit's Avatar
Cat operation.
Great info.....thank you!
Old Aug 28, 2012 | 07:16 AM
Those little 'soda' can size aftermarket cats.
I have a CIA downpipe up in the 'rafters', of the garage,
covered with dust...
I bought a larger $300 aftermarket cat too, from Random Tech, & tryed
it in the CIA downpipe, down towards the end of the downpipe.
Nothing beats the size & volume, of the stock, 1st cat, in the location,
that it is in.
You just need to free up the restriction, of that 2nd cat, & just sliding in a
2.75" piece of tubing, does the job.
If you just gut the 2nd gut, without the tubing, flow is screwed up, been there, done that...
Old Aug 29, 2012 | 10:59 AM
MIKEYfixit's Avatar
that it is in.
I LIKE this idea. I just don't have the money for an after market exhaust system. I was thinking of the muffler delete to get some more sound out of this car. I like to shift by sound rather than watching the tach. The question I have is that the stock down pipe looks like it is restrictive where its flattened for the bung hole, an aftermarket down pipe wouldn't flow better? thanks!
Old Aug 29, 2012 | 11:09 AM
Originally Posted by MIKEYfixit
I LIKE this idea. The question I have is that the stock down pipe looks like it is restrictive where its flattened for the bung hole, an aftermarket down pipe wouldn't flow better? thanks!
It's not an issue at all.
Still 3" in this area.
I turn mid 12's @ 111mph at the track with this modded stock downpipe...
Old Aug 29, 2012 | 11:56 PM
MIKEYfixit's Avatar
thanks!...i gotta do this low dollar mod!
