No lift shift problems
Every car has a different feeling, and with this car I was just seeing if it was just me or if there was anyone else experiencing the same problems.
dont change the trans fluid...GM has a specific fluid in them....I work on Saab's that use the basic same trans, and trust me there is no reason to change....please no flaming thats just from what we have seen.
No-lift in competion mode works great for me... Man, it really rips thru the gears when you have that turbo wound up!
I have had plenty of practice over the years with my Firebirds!
I have never missed a gear or had trouble shifting the SS (other than 5th once in a while while I am driving like a grandma!) I tried speed shifting tonight with traction control and stability control both disabled to see the difference, and it wasn't much... Just rocketed down that backroad once the 1st gear tire smoke stopped!
The main thing I notice when using Competion Mode off the line is it kind of stumbles quite a bit while it is trying to limit that tire spin.
I have had it work a couple of times, but not once at the track. I called my local Chevy dealer and they have not heard of any trans problems for the SS yet. So I guess I'm going to be the Ginni Pig.
is this competition mode only activated when you put the gas to the floor with the clutch depressed and its bouncing off the rev limiter?..or if you take off normal from a light and then decide to shift it with the NLS(no lift shift) into 2nd will it still work?
I want to try it and wan't to be certain to get it right the first time.
I went to the track this past Sat. to try out the fancy no lift shift on my SS. I have a 5 speed and every time I tried to shift into the next gear it would not go in with out double clutching. Needless to say this was very annoying. It is also hard to shift into 5th gear below 55 mph.
Is anyone else experiencing any shifting problems with their cars or is it just me.
Oh, and I just came from an '05 Cobalt SS/SC which has virtually the same tranny. That car suffered HORRIBLE wheel hop at the top of 1st and if the car was hopping, the tranny wouldn't go into gear either.
Agreed, and based on my 2 attempts, I don't have the no-lift technique down either. However, having driven many turbo cars over the years (and I drag raced turbo bikes for years), I've got my own 'throttle blip' technique for keeping the spool up.
