Is this normal?
Old Oct 29, 2008 | 08:16 AM
foolmoon_design's Avatar
Is this normal?
It is in the 30's here in Floridia the past couple of days, and I am only seeing a steady boost of about 8-10 PSI then it climbs wit the RPMs to 14-15 right before the shift, then back down to 8-10.........?????????
I am a "Newb"..... so is this the ECM regulating boost because of the ambient temperature? or have I finally been visited by the "lost vacumn" fairy?
Any help would be appreciated, before i decide to give up my car for a few days.
Intuition made me find what I thought were the vac hoses, and all seemed fine, I could be missing one or two......
Old Oct 29, 2008 | 08:20 AM
crazysteve's Avatar
how does it run....if it still runs ok i would say you are fine....colder denser air does not take as much boost to make the power.
Old Oct 29, 2008 | 08:28 AM
It still runs well, I think problem is me! How are the mods comming?
Old Oct 29, 2008 | 09:58 AM
hurst equipped's Avatar
i just drove a brand new '09 ss auto and it does the same thing.
Old Oct 29, 2008 | 10:39 AM
ts5p's Avatar
1st and 2nd boost is limited around 5 to 10psi i think
3rd and 4th are still limited but not as much i have seen 16psi in the auto
this is most likely because they limit the HP in 1st and 2nd to 235
and in 3rd and 4th to 250
Old Oct 29, 2008 | 04:14 PM
cannuck's Avatar
boost runs off your exhuast gas, plus the computer has decided that 1st and 2nd gear cant handle the truth. thats why the tune has the answer
Old Oct 29, 2008 | 04:19 PM
ts5p's Avatar
what i do not get is if the trans can not handle the full power of the engine how is it gm is going to explain the upgraded tune when they finally release it
Old Oct 29, 2008 | 04:35 PM
white heat's Avatar
On pcm controlled boost, the boost is always lower in colder weather. Denser air molecules in colder air so less boost is needed.
LolaIsMyHHR
May 17, 2012 06:55 PM
GDZHHR
Sep 16, 2009 08:17 PM
ecaryn
Aug 5, 2009 12:11 AM
camaro98z28
Dec 30, 2008 10:08 AM
Graunkem
2.4L Performance Tech
7
May 31, 2008 07:14 AM
