P0101
Old Jan 30, 2020 | 07:01 PM
Shwestcoat's Avatar
P0101
Originally Posted by ssdivin
can someone tell me where each hose goes
part 12622040
Can someone tell me the name of the part and where to find it ive replaced everything else and still can not build boost
ive searched the part number and cannot find anything about it
Old Jan 30, 2020 | 07:24 PM
Looks like the turbo boost sensor, perhaps RJ or FMG can positively identify it.
Old Jan 30, 2020 | 07:25 PM
I can't find any reference to that part number.
The part in the picture is the bypass solenoid, GM P/N 12653854. Another number is 12634111, superseded now by 12633355.
There are several reasons why you can't generate boost. What code(s) are you getting?
Old Jan 30, 2020 | 07:28 PM
RJ , that P/N doesn’t show up , possibly obsolete?
Old Jan 30, 2020 | 07:30 PM
Shwestcoat's Avatar
I had alot of codes replaced the intercooler and maf and smoked the system and now i only have codes for the maf p0101 sometimes it will boost to 8psi sometimes 0psi
I was just editing
Old Jan 30, 2020 | 07:36 PM
Probably a vacuum/boost leak.
Intercooler plastic ends, charge piping or clamps, vaccum tank, the list goes on and on...
What mods do you have?
Old Jan 30, 2020 | 07:41 PM
Shwestcoat's Avatar
The only mods on the car are muffler delete and zzp fmic. The stock intercooler plastic ends cracked so i upgraded. Also when they installed the maf the used a hitachi instead of a bosch so they are going to order the bosch to see if that turns the light off and if it builds boost again
Debating doing the vaccum tank delete to see if that is what is causing the issue
Old Jan 30, 2020 | 09:35 PM
Do not do a vacuum tank delete. The system has to have a reserve supply of vacuum for the turbo system to operate correctly. Under a heavy load, the engine produces minimal or no vacuum. Without a tank to hold that reserve, the system has nothing to draw from when the engine is not producing a vacuum.
Old Jan 30, 2020 | 11:55 PM
Shwestcoat's Avatar
i would only be doing the delete to see if the tank was cracked causing the loss of boost. I would be replacing afterward
Rudy Jimenez
Jul 29, 2019 12:17 AM
Chadwick09
10
Mar 2, 2018 10:31 PM
SHAGGYMEOW
49
Jun 4, 2016 06:39 AM
JJ's BLACK SS
40
Apr 22, 2010 05:48 AM
jonboyb
Jan 30, 2008 07:09 PM
