P0101 issue
Old May 10, 2021 | 04:10 PM
  #31
FlawdaSS's Avatar
I bought a mew AC delco MAF and see what happens. Thank you all for the help. I'll be in touch
Old May 10, 2021 | 04:11 PM
  #32
From obdcodes.com:
Carefully clean the MAF using MAF cleaner spray is generally a good DIY friendly diagnostic/repair step
Loss of vacuum to the MAP sensor can trigger this DTC
Read more at: https://www.obd-codes.com/p0101
Copyright OBD-Codes.com
So did you use specific, MAF sensor cleaner?
And check that MAP sensor for vaccum.
EDIT: I thought you had cleaned the MAF sensor, but now I don't see that you had tried that.
hurst2001
Oct 9, 2020 04:20 PM
bg2376
Mar 25, 2017 06:12 PM
fonque
0
Jun 1, 2015 12:20 AM
Lee3333
2.4L Performance Tech
Aug 1, 2008 02:27 PM
1 BAD HHR
42
Apr 29, 2006 10:49 PM
