MAF Problems
Old Feb 6, 2006 | 06:36 PM
1 BAD HHR's Avatar
MAF Problems
I recently built a CAI for my HHR. The problem is that when the MAF is plugged in the engine starts to sputter and then stalls. If I unplug it, the engine runs almost perfect, but the CEL comes on and the tranny seems a bit rough at the shift points.
Anyone have any ideas on what would cause this, and/or how to fix it???
Old Feb 6, 2006 | 07:04 PM
SoCalHHR's Avatar
Are you using an oiled filter like a K&N?
That (excess oil up the tube), could cause the MAF sensor to foul eventually.
Old Feb 6, 2006 | 07:29 PM
1 BAD HHR's Avatar
I opted not to use an oiled filter right away, as I've heard of the fouling issue on other intakes. Besides, the MAF problem is instant once its plugged in. I also know that there isn't anything wrong with the MAF itself, since I can put the stock setup back together and all is well again.
Any other thoughts, Mike??
Old Feb 6, 2006 | 07:33 PM
SoCalHHR's Avatar
Then it sounds computer related to me. Perhaps the increased flow is tricking the ECU. Have you tried driving it around a bit? It should calibrate itself unless your runner diameter and length is waaay off. We found that the HHR likes to see a little smaller diameter tube thean you would guess. Velocity must be kept up for the FI.
Hopefully snksknr94 will step in wih a REAL answer!
Old Feb 6, 2006 | 07:38 PM
captain howdy's Avatar
You disconected the battery so the computer reset and recalibrated right?
Old Feb 6, 2006 | 07:39 PM
1 BAD HHR's Avatar
Yeah , I read on one of the cobalt forums that someone had a similar problem with a Fujita intake. It was suggested that he try just running around with it, hoping that the ECU would recal itself. Problem is that usually my engine dies before I can get out of the driveway. Maybe I'll try that in the morning.
The only other thing I've found as a thought is to by ZZPerformance's Mini-AFC 2.2 (its supposedly made for the Ecotec engine only), to program the air/fuel mix. Problem is that costs $180. That's more than I'm going to spend for a homemade intake.
Old Feb 6, 2006 | 07:40 PM
1 BAD HHR's Avatar
I tried that, too. Left he battery's "-" terminal off for 20 minutes. Still had the same problem.
Old Feb 6, 2006 | 07:46 PM
snksknr94's Avatar
Get it scanned and see what code is setting the light. I can't help out with having a little more info. Other than that put it back to stock and wait until somebody comes out a CAI. You sure it goes back to normal after putting the stock stuff back on, sounds like maybe you damaged the fins on the MAF.
Old Feb 6, 2006 | 08:00 PM
1 BAD HHR's Avatar
I'm positive about everything going back to normal when I return it to stock. The CEL turns off ( the CEL only lights when the MAF is unplugged), and the tranny feels smooth at the shift points. What's your opinion on running it for a little while to see if the ECU recal's itself??
Old Feb 6, 2006 | 08:20 PM
snksknr94's Avatar
It should recal itself after just a couple of minutes of running but if it is dying before that something else is wrong. Are you leaving the MAF unplugged with the home-made stuff hooked up? I kinda got that impression from your above statement. Do the cooling fans kick on when the light comes on as well?
