Possible to switch the ss to ls or lt knuckles?
We’re not discussing axles here. As for knuckles see if the G6 part numbers cross reference, now I looked and the only models that these 2 part numbers apply to are the Cobalt and HHR SS models, so that got me thinking is it plausible that the only difference is the ball joint stub mounting opening? The SS would be 20.6mm the LS/LT 19.6 if so all you need to do would be install the smaller ball joint stub.
so the g6 knuckle seems to fit, got it off an 08 pontiac g6 hub goes in and everything else mocked up nicely. just gotta tighten the bolts do the other side n get an alignment will post pics soon forgot how backbreaking it is to break axle nuts.
