Possible to switch the ss to ls or lt knuckles?
Old Feb 8, 2024 | 08:43 AM
SS axles are different and hard to find. If it says "fits all" it does not fit SS.
Stamped LCA are not for any HHR.
Old Feb 12, 2024 | 12:21 PM
Bazzertwaz's Avatar
aw ss axles switched to gm8xxx or something like that forgot the number they work just fine. anyone know if a g6 knuckle would fit? I heard somewhere they might.
Old Feb 12, 2024 | 12:55 PM
We’re not discussing axles here. As for knuckles see if the G6 part numbers cross reference, now I looked and the only models that these 2 part numbers apply to are the Cobalt and HHR SS models, so that got me thinking is it plausible that the only difference is the ball joint stub mounting opening? The SS would be 20.6mm the LS/LT 19.6 if so all you need to do would be install the smaller ball joint stub.
Old Feb 16, 2024 | 03:50 PM
Bazzertwaz's Avatar
so the g6 knuckle seems to fit, got it off an 08 pontiac g6 hub goes in and everything else mocked up nicely. just gotta tighten the bolts do the other side n get an alignment will post pics soon forgot how backbreaking it is to break axle nuts.
Old Feb 16, 2024 | 03:54 PM
Bazzertwaz's Avatar
the LCA is not the fe5 though so I don't know if it'd work with one I can always just bore it out. ill try to see if I can find a caliper so I can measure it
Old Feb 16, 2024 | 04:42 PM
Axle nuts are easy , socket then 24” Johnson bar and the jack handle or a length of 1 1/2 “ pipe for leverage.
confused about the LCA , what do you need to bore out?
Old Feb 16, 2024 | 08:31 PM
Bazzertwaz's Avatar
couldn't find my bar . the ball joint hole in the knuckle seems to be smaller, it fit my fe3 LCA fine but don't know if the SS ones would fit. well ill cross that bridge when I get em.
Old Feb 16, 2024 | 10:33 PM
I thought the point was to use LS/LT LCAs ball joints.
Old Feb 17, 2024 | 07:24 AM
Yes, drill out the rivets and install LS/LT ball joint
Old Feb 17, 2024 | 03:13 PM
2005HHRauto's Avatar
Originally Posted by bazzertwaz
just looking for some info i tried searching and came up with nothing. Is it possible to switch the ss knuckles bearings/hubs and cv axles to a ls or lt model?
You need to switch the control arms also.
yes it will work
