questions on 3 bar map sensors?
im looking into a set of 3 bar map sensors, the sensors are new and include the instillation instructions. is that all that is included in the kit? i just dont want to be missing anything.
someone is selling them and they just have the sensors. http://www.cobaltss.net/gallery/file...2/9/sensor.jpg
The instructions have a specific code that the dealers will need when uploading the GMTU tune into your car. Should be 2 orings in there also for both sensors. Crimp connectors should be included. Judging by the picture, that is the older crimp style connections. This link will show you everything that it should with.
http://www.gmpartsdirect.com/results...umber=19212670
wish I knew about a month ago you were wanting to upgrade your MAP sensors. I sold a pair of upper and lower 3 bar MAP sensors for $30 bucks!
but as stated before, you will need the correct O-Ring's for sure
does this kit come with the o-rings? cant i re-use my o-rings?
