Reduced eng performance
09 ssHHR 56kmi 5 spd reduced eng performance warning came on, went into limp home mode using synthetic oil , the warning system was still set to original system , raised hood everything is still hooked up , IDEAS? TERRY
Check Engine Light on ? Even if it isn't, you need to pull the codes. You have one (or more ) that has triggered the reduced power.
Post them up here (numbers only, no descriptions) and we should be able to point you to the problem. |
X2, codes please, and how old is that battery?? Original??
I think normally the reduced power problem is 9/10 times related to the throttle body and/or accelerator pedal, no?
Originally Posted by aradmahogany
(Post 842341)
CODE P0087 [fuel rail pressure too low?]
HPFP? Or is that a different code?
The HPFP could effect rail pressure, I am sure.
So will the fuel pressure regulator and the low pressure pump, I just read the article for the code, it doesn’t mention anything about HPFP
