Some corners have serious positive camber, which helps the G's. Like the banking at Daytona.
I still have stock rubber. It's not the best grip possible, but they are very predictable. I will get summer rubber on it eventually. I just bought the car new in June and am still settling in. I think I will change the front motor mount. The car jitters when I back up (it's a manual). I'm guessing it's the mount. The motor in the signature is a 2.2 liter flat four in my old midengine Porsche 550 Replica (the car James Dean died in). This is not a lookalike, but a very close copy of the original, of which only about 60 were made. Real ones are worth around 1 million dollars. You can see the cool air intake that went to the cooling fan. And also the intercooler, which sat under the other opening in the rear clamshell 'hood.' The car was a 'blow through' turbo with dual twin throat 44 webers. I had the original 155 hp engine turbo'ed and intercooled. 20 lbs of boost. Probably made more than 300 hp. Since the name '550' was the weight of the car, in kilograms, the weight of my Porsche was about 1250 lbs. With this type of power, it was faster than my 600 hp Viper. It would do 70 to 150 in about 6 seconds. You should have seen the guys faces, in their $100,000 plus Porshe Turbo's, when I blew their doors off! But I would have lost my life, or my license, if I'd kept it much longer. Handled great too. |
Originally Posted by TurboTechRacing
(Post 590574)
Thank you for this great review!
Now try the Upper Engine mount, another great addition to reduce wheel hop, increase throttle responce, avoid breaking exhaust flex joints, and looks much better than the stock mount! thanks, mike |
Originally Posted by ChevyGuySS
(Post 591111)
hey TTR, do you think you can send a like to a PDF of the install instructions for installing the rear sway bar?
thanks, mike |
are there pre drilled holes or does it all just bolt up? george did you notice a big difference between it on and off?
(Post 591186)
(Post 591186)
Install = jack placed to support passenger side of engine. Remove cold air duct. Remove three windshield washer nuts. Move windshield washer reservoir out of way. Remove engine mount bolts. Remove mount. Install new TTR mount. Re-install everything. 10-15 minutes tops. :smile: everytime you drive even more. |
Originally Posted by JeramieJJ
(Post 591207)
difference = HUGE No torque steer! Power to the ground when you punch it. Cornering hard is fun also.
(Post 591186)
Once you get under the car, you'll see right away where it goes. I used a zip tie to hold it up in place, installed the four bolts, and cut the tie. Done in about 20 minutes. During my test drive I couldn't get the smile off my face. |
(Post 591186)
(Post 591234)
..........Someone on here once used the term "slot car".
That's my line....... :lol: |
