smog test after mods
has anyone here did a downpipe without cats or one cat and did the car pass smog, southern Cal. or a smog state.
You will fail without a CAT because I'm assuming the guideline for smog in Cali is strict. Just get the DP with the CAT from HAHN. I did. ;)
You will fail in Cali if you not only not have a Cat but the correct cat for your vehickle. CARB changed Cat rules this year.
I think he meant did it pass the sniffer..not the visual
Originally Posted by IgottaWoody
(Post 373869)
What good is it to pass the siffer if you can't pass the visual? Failed is failed. Un less if you are in Cali and it is the death penalty. |
maybe inquiring minds want to know..........
i planing to cut my exhaust pipe behind the first cat, placing a flange and angle bum fitting for the c02 sensor, another flange for the 3" exhaust, making all look like factory,
so if it fails i simply put back the second cat and sensor back in place using the flange connection. should pass visual, dont know about how much the second cat effects smog limits, i been told the second cat just burns unburnt gasses. |
Originally Posted by tony326
(Post 373953)
I wouldn't do anything in Kalifornia except move to another state. If I was stuck there, I'd have a pre-1975 hot rod.
Where is the second cat. on a HHR ? Is this a cal. only thing ?
