smog test after mods
Old Apr 4, 2009 | 10:31 PM
tony326's Avatar
has anyone here did a downpipe without cats or one cat and did the car pass smog, southern Cal. or a smog state.
Old Apr 6, 2009 | 12:06 PM
camaro98z28's Avatar
You will fail without a CAT because I'm assuming the guideline for smog in Cali is strict. Just get the DP with the CAT from HAHN. I did.
Old Apr 6, 2009 | 01:23 PM
hyperv6's Avatar
You will fail in Cali if you not only not have a Cat but the correct cat for your vehickle. CARB changed Cat rules this year.
Old Apr 6, 2009 | 04:53 PM
IgottaWoody's Avatar
I think he meant did it pass the sniffer..not the visual
Old Apr 6, 2009 | 06:17 PM
hyperv6's Avatar
What good is it to pass the siffer if you can't pass the visual?
Failed is failed. Un less if you are in Cali and it is the death penalty.
Old Apr 6, 2009 | 07:24 PM
maybe inquiring minds want to know..........
Old Apr 6, 2009 | 09:52 PM
tony326's Avatar
i planing to cut my exhaust pipe behind the first cat, placing a flange and angle bum fitting for the c02 sensor, another flange for the 3" exhaust, making all look like factory,
so if it fails i simply put back the second cat and sensor back in place using the flange connection. should pass visual, dont know about how much the second cat effects smog limits, i been told the second cat just burns unburnt gasses.
Old Apr 7, 2009 | 01:15 AM
RoadDawg831's Avatar
You're most likely going to fail the visual. Smog techs have exhaust and smog systems diagrams for every vehicle which they reference if there's any doubt about what they're looking at.
Old Apr 7, 2009 | 06:49 AM
mistermike's Avatar
I wouldn't do anything in Kalifornia except move to another state. If I was stuck there, I'd have a pre-1975 hot rod.
Old Apr 7, 2009 | 06:57 AM
oneton's Avatar
Where is the second cat. on a HHR ? Is this a cal. only thing ?
