So Close I Can Almost Taste It!
Just received the latest dealer update and the word is my SS came off the railcar yesterday and is at the CA port awaiting truckload consolidation and delivery to them by end of this week or early next week. Looks like I'm finally in the homestretch!
Ordered the turbo upgrade kit from CrateEngine Depot so the trick is going to be to get it here in time to hopefully get an install at delivery and suck up that maximum warranty term. I'm also up against a 1% increase in our state sales tax effective on April 1 so all this should make for an interesting next week or so.
As long as your dealer has the VIN# you can purchase the car, mine won't be here until April but I'm buying it on the 29th to take advantage of the 0-60 Financing.
Byron
I'm not sure they will clay bar it unless you check the paint closely. Try not to be too excited about the new wheels and really take a close up walk around to make sure. I assume the dealer will give you a quick wash(detail
) Look real close.
) Look real close.
Thanks! I only want the dealer to wash it off for me to be able to inspect it. It will then go directly to a friend's detail shop for the works, including the clay bar. Did the same thing last year when I bought my Bullitt Mustang and it worked out just fine that way. That car was loaded with rail dust from the MI to CA ride.
I talked to CrateEngine Depot about the stage kit today and they still don't have 'em. May have to forgo trying to get mine installed at delivery which is not a total loss as it gives me the opportunity to be sure the car is sorted out and running good beforehand and I'll have a baseline to compare the performance afterwards.
