Soldered in MAP sensor, but still have intermittent boost issues
Old Nov 17, 2017 | 02:27 PM
ACLR8R's Avatar
Anyone still have issues after they solder it? I know its the wires because I can "jiggle" them and boost comes back, I am thinking its maybe a break in the wire somewhere else or maybe bad pin crimp? Just wondering if anyone else has had a similar issue.
Old Nov 17, 2017 | 03:10 PM
The jiggle test is pretty definite, something is loose. You need to isolate it by holding the wires while jiggling.
My bet would be near where the sensor bangs into the A/C.
Old Nov 17, 2017 | 03:22 PM
Yes, I’ve had similar wiring issues , I isolate the section of wire, from connection to connection and replace the entire length, if it’s brittle and broke in one spot it’s gonna break again!
Old Nov 18, 2017 | 06:28 AM
ACLR8R's Avatar
Its the upper map sensor, and I know its the wire furthest to the passenger side. Should I just replace that wire?
Old Nov 18, 2017 | 07:16 AM
If it has a continuity issue then yes.
87ninefiveone
Sep 30, 2016 11:32 AM
allij0812
Dec 12, 2013 11:16 PM
bigjacksauto
Jul 7, 2013 08:44 PM
gmdealerguy
Mar 17, 2010 11:21 AM
