Squeeeeeeeeeeeeeeeeeal
Old Nov 14, 2008 | 02:23 PM
Chevy SS's Avatar
I have no problem controlling the traction. You just can't slam the throttle down, this will result in loss of traction. I can smoothly and quickly accelerate with no problem. Practice a little, you will get used to it.
Old Nov 14, 2008 | 02:59 PM
08redhhrss's Avatar
Wink
it's definently controlable......but it is so much fun to squeeze the throttle down until the turbo spools and break the tires loose. We all have the ability to not "slam" the throttle down, but its soooo much fun!! Thanks for the tip though
Old Nov 15, 2008 | 12:49 PM
white heat's Avatar
Exactly. Sounds like some of you need the driver mod.
Old Nov 15, 2008 | 01:57 PM
MOTRV8D's Avatar
the thread title reminded me of a certain movie with Burt Reynolds and Jon Voight... if ya know what I mean!
Old Nov 15, 2008 | 02:10 PM
ChevyMgr's Avatar
Ned Beatty might know what you mean........
Old Nov 15, 2008 | 02:18 PM
IgottaWoody's Avatar
Simple fix..remove and replace the steering wheel actuator....
Old Nov 17, 2008 | 07:35 AM
jerSSey HHR's Avatar
If the pavement is a tad wet, I get squeal even from an SS auto running regular fuel. And don't go anywhere near the painted crosswalks. Those things are made of thermosplastics and are real slippery.
Old Nov 17, 2008 | 07:38 AM
halfpanel08's Avatar
saturday i finally got my tires to white smoke . ive tried time n time again to get my little hhr ls 2.2 to do a "burnout".. and finally got it done!
Old Nov 17, 2008 | 10:53 AM
tomw's Avatar
He has a really nice mouth........
Old Dec 5, 2008 | 01:10 PM
R CA HHR's Avatar
I get the same thing in my 2.4. If I even get on it alittle the tires will spin and squeal a bit and the torue steer comes into play which I like because it helps keep you awake.
On another note when I try to peel out and squeal the tires it seems it doesn't want to, it just does a lil more than when it happens by accident, just kinda weird.
