SS Auto
Hi guys:
I own 4 HHRs, but not an SS so I am not too familiar with them. I have a friend looking at a 2010 HHR SS Automatic with 140K miles and he had some questions. 1) As I understand it from searching the SS forum, the SS automatic engine can be brought up to the power of the SS manual with just a tune, is that correct? 2) The tune mentioned above would have minimal effect on the trans life? Obviously it must have some effect otherwise chevy wouldn't have reduced the power? Thanks Steve |
1:yes
2: will be fine. 4t45e transmission is very durable. |
Originally Posted by Ohiocruiser
(Post 860686)
1:yes
2: will be fine. 4t45e transmission is very durable. I will pass the info to him. Steve |
FYI. A "tune" depended on which one, is most likely going to give you more power than the stock manual SS. There isn't a lot of difference between the stock numbers of manual vs standard. 235/250hp (235 in lower gears or something) vs the 260hp in the manual.
The SS auto trans is generally considered strong enough to handle around 350 hp or so. |
