SS oil change
Old Aug 7, 2008 | 12:29 PM
405HP_Z06's Avatar
Originally Posted by XXL
Bueno. I'll throw myself in front of the next Strap-On truck I see (since I don't work anywhere they'd make a stop for). I think the tool combo will still need a stubby ratchet... which I have. It's pretty tight in there, and with the clearance problems I mentioned in my OP, just 'extensioning' up doesn't help.
I purchased it from www.snapon.com; I don't have access to a truck either.
As far as the stubby ratchet, not required. I used a 'u-joint' socket and 12" extension, it worked perfectly.
Old Aug 7, 2008 | 01:23 PM
XXL's Avatar
XXL
Sounds good. Maybe it's the limitation of the u-joint I mocked up in there (with a stubby socket that isn't the right size), but I couldn't get around that black metal bracket that stabilized the IC pipe. Sounds like if I source the Strap-On socket, I should be all set then. Thanks.
Old Aug 7, 2008 | 01:37 PM
XXL's Avatar
XXL
FYI, Strap-On is about $35 landed. Since this isn't a high-torque application, For anyone looking to buy online, I bought the Lisle unit for about $9 landed here. They have free shipping on the $6.xx part with a $2.xx "handling fee."
Old Aug 7, 2008 | 05:05 PM
jerSSey HHR's Avatar
Does this mean the boys at Monro or Pep BOys will have no clue how to change the oil?
Old Aug 7, 2008 | 11:05 PM
turbotech's Avatar
Unfortunately they probably already have the tool.I've replaced plenty of plastic oil filter caps that came from Quick lube places. Also, FYI, the oil filter has a little nipple with an o-ring at the bottom. If that nipple breaks off due to missinstallation, it will go into the oil galleys and plug the oil supply to the cylinder head and camshafts. You will get a lifter ticking noise to let you know your engine is going to crater. This has been done by several quick lube places. The cars (all Ecotech engines) will ussually come to the dealer for repair (removal of head and clean out galley, $$$$$). Just a FYI. I've been into a few 2.2's and 2.4's already. Made 2 car payments on the new SS with those jobs.
Old Aug 7, 2008 | 11:46 PM
405HP_Z06's Avatar
Here's how it fits as I explained above, sorry about the blurriness.
Old Aug 8, 2008 | 06:23 AM
Jeff®'s Avatar
Originally Posted by HHR 'Black Death'
Okay so I read the post. All I have to say is WOW! I have NEVER see a filter like that!
Go ahead and ask what rock I have been under!
The rock next to mine.
Old Aug 8, 2008 | 10:19 AM
XXL's Avatar
XXL
Hey, these are retro cars... what's old is new...
1956-57 Oil Filter Canister
Old Aug 9, 2008 | 12:38 AM
XXL's Avatar
XXL
Wowza... landed today. That's overnight from when I placed my order (They're in CA. So am I. But still impressive.)
Old Aug 9, 2008 | 11:23 AM
BZERKED's Avatar
It was a snap to change out. I had to laugh on my first change becasue I didnt know she was on the top.. lol Nice and Simple.. FOR ONCE! I had a 32mm beater socket and cut it down on a lathe. Works like a champ!
