Hi. I have a 2009 SS Panel. I’m gonna redo my suspension. I’m ordering the KYB struts and shocks from ZZP. I can’t get OEM springs and I’m not interested in AC Delco’s aftermarket. Can anyone recommend good springs? I want to keep the car stock height. The most I’m willing to lower it would be 1” if I have no other choice. Thanks in advance.
We get a discount from RockAuto! They have KYB struts and shocks
as for OEM springs for FE5 , front springs for a manual transmission FE5 SS are still available
The part number depicts, for left side , but the springs should be the same for both sides.
Also there seems to a lot of confusion about difference and commonality w/ Cobalt FE5 vs. HHR FE5. Not just owners, parts suppliers too. I’m trying to work up the inspiration to make a spreadsheet.
I just know the front springs for an SS automatic are now obsolete, the aftermarket has the it’ll fit kind but wrong spring rate and wrong static spring height
I just redid my suspension 2 weeks ago. I gave up trying to find stock springs and bought a set of Eibach sportlines. They are low, but they ride pretty well with oem FE5 struts and shocks.
I'm going to revive this thread. I've got a manual transmission SS w/FE5. I know the shocks are NLA so I bought KYB. What about the springs? I can't find them OE. What do you use instead?
What’s wrong with your current springs ? Unless you have broken coils , they’re probably still good.
There is always the wrecking yard. There are wrecked SS’s available. Do a Google search.
