Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Steering position sensor (https://www.chevyhhr.net/forums/hhr-ss-45/steering-position-sensor-67250/)
Oldblue Nov 10, 2024 11:00 AM
Pretty sure the traction control light is the key to this, that would be the wheel bearing hub speed sensors unplugged or loose, possibly a bent pin. This could be the problem.
RJ_RS_SS_350 Nov 10, 2024 11:10 AM
Unless the car has been in a collision, you don't need to replace the sway bar. It doesn't have boots. There are bushings that should be replaced as needed.
The grinding starter is a separate problem from sway bar, steering, or brakes.
Try http://Car-part.com for used parts.
donbrew Nov 10, 2024 11:19 AM
Ask what the code number is!
